Long lasting and hard-wearing, the VRH150X USB Rechargeable Headtorch offers up to 360 hours of light from one single charge*.
Alongside the twin colour output and variable brightness levels, the hard-wearing rubberised outer and IP64 water and dust resistance makes the VRH150X an essential item for your fishing, camping and hiking trips.
With adjustable brightness ranging from 30-160 lumens, the VRH150X is perfect for dark nights and overnight stays. The headtorch also features a clever night location setting which enables you to keep the headtorch on at 1% power, ensuring that you can easily find your headtorch in the dark.
*tested and achieved using the night location feature, using 1% power.
- Triple high powered LED output
- Dual colour, variable brightness: 30-160 lumens
- Five beam options to suit all situations
- Night location feature
- High capacity 1400mAh lithium-ion battery
- Quad LED power display
- Compatible with all common 5v USB charge adaptors
- Simple push button control
- IP64 water & dust resistance
- Dual orientation with 90-degree tilt function and twin on/off buttons
- Protected registered design
Specifications
- Charge time: 3-3.5 hours
- Battery life @ 15C: up to 360 hours (on night location mode) / up to 80 hours (dependant on mode)
- H40mm x W60mm x D50mm (without strap)
- Approximate strap length: 50cm to 65cm (fully elasticated)
RM HT 150X
