The RidgeMonkey Bivvy Lite Elite IR: the ultimate guiding light in the dark. With variable brightness to suit your needs, the option to switch between three colours at the push of a button and up to 180 hours of illumination from a single charge via a standard 5V USB port.
The Bivvy Lite Elite IR sports a compact, lightweight design with magnetic fittings and backing plate, meaning it can attach to any bivvy, brolly, awning or tent as well as any nearby ferrous metal for your convenience.
The smooth brightness control function offers a user-friendly variable glow that can be adjusted using the integral multi-function button or included wireless remote fob, while the IP64-certified construction means the Bivvy Lite Elite IR can be used in all weather conditions without fear of dust or water ingress.
PRODUCT SPECIFICATION
- Lumens: 10-100 (dependent on setting)
- Battery life @ 15C: 6-180 hours (dependent on setting)
- Battery capacity: 2600mAh
- Recharge time: 4-4.5 hours
- IP64 Dust & Water Resistant
- Approximate Dimensions: 205mm x 38mm x 38mm
- Three colours – white, red and green
- Smooth brightness control
- Wireless remote control
- Built-in rechargeable lithium-ion battery
- Quad LED power indicator
- Micro USB charging port
- Sealed IP64 dust and water resistant casing
- Robust construction with sleek GunMetal Grey finish
- Protected registered design
- Adjustable Bankstick Adaptor included
