RidgeMonkey Multi Lite Plus
£34.99 Inc VAT
Out of stock
SKU: 5056210606353 Categories: , , Tag:
The Multi Lite Plus works as a powerful spotlight, a triple colour lantern Red White and Green output complete with variable brightness levels whilst featuring a supplied removable spotlight diffuser and universal tripod fitting with adjustable bankstick adaptor perfectly suited to perfecting your night catch photography.
The days of fumbling around in the dark looking for replacement batteries are gone – simply connect to any USB charger to top up the
internal lithium-ion cell.
Featuring a hard wearing rubberised outer and IP64 water resistance, the Multi Lite Plus offers market-leading torch design and functionality in a compact, simple to use package.
  • Multiple high-powered LED output
  • Triple colour Red White Green
  • Variable brightness
  • Narrow spotlight and 360º floodlight options
  • Removable spotlight diffuser
  • High capacity 2000mAh lithium-ion battery
  • LED charging indicator
  • Compatible with all common 5v USB charge adaptors
  • Simple push button control
  • IP64 water resistance
  • Magnetic & universal tripod fittings
  • Adjustable bankstick adaptor
  • Hanging ring
  • Protected registered design
  • Charge time:3-3.5 hours
  • Battery life @ 15C:up to 150 hours
  • Floodlight lumens: 10-100 (dependent on setting)
  • Floodlight battery life @ 15C: 4-150 hours (dependent on setting)
  • Spotlight lumens: 145
  • Spotlight battery life @ 15C:3 hours
  • Battery capacity:2000mAh
  • Recharge time: 3-3.5 hours
  • IP64 Dust & Water Resistant
  • Approximate Dimensions:125mm x 45mm x 45mm
Ridgemonkey
Be the first to review “RidgeMonkey Multi Lite Plus”
You may also like…
£34.99 Inc VAT
