Why use a number of different pans when you can cook a whole meal in just one? Featuring a traditional deep-sided frying pan, a four-section multi-purpose pan and removable steamer tray, the RidgeMonkey Connect Combi and Steamer Set will help you to create a different offering every day. Free recipe ideas booklet included!
- 1x flat-bottomed frying pan
- 1x four-section multi-purpose pan
- Lightweight aluminium construction
- Sleek Gunmetal Grey finish
- Fluoropolymer non-stick coating
- Ridged exterior for even heat transfer
- Detachable hinge system
- Removable handles with protective pouch
- Can be used on all traditional stoves (not suitable for use on induction hobs)
Approximate dimensions
- 300mm x 255mm x 70mm (handles removed)
- 440mm x 255mm x 70mm (handles fitted)
Reviews (2)
2 reviews for Ridgemonkey Connect Combi & Steamer Set
keith.mottershead70 (verified owner) –
Just been away for a few days and used this for the first time, was great for both breakfast and Dinner cooking. Plenty big enough for 2 meals and easy to clean. Just purchased the XL toaster to go with it.
shelleychell (verified owner) –
Couldn’t find cheaper anywhere else so I treated myself to both this and the Connect Multi-Purpose Pan & Griddle Set to go with our xl toaster, fantastic kit all of it. Delivery was great and quick!!
