Coleman BatteryGuard™ 600L LED Lantern
£14.99 Inc VAT
Out of stock
BatteryGuard ™ 600L LED lantern is an indispensable companion on every camping trip, as well as in the home. The lantern is equipped with “Lifetime LEDs” with an expected lifespan of 40,000 hours.
Thanks to the unbreakable 360° polycarbonate glass, there is no unwanted shadow cast by annoying plastic parts on the lamp. The BatteryGuard ™ function is integrated with the on-off switch of the lamp and prevents the batteries from leaking or losing energy.
  • Light output: 600 lumens
  • Light range: 12/6 meters
  • Burning time: 30/200 hours
  • Battery: 4 x D batteries (not included)
  • BatteryGuard ™ technology
  • IPX level: IPX 4
  • Dimensions: 12 x 22 cm
  • Weight: 494 g
BatteryGuard™ technology disengages the battery from the electric contacts with a single slide movement. Once the electric light has been switched off, you are sure to prevent battery loss. In addition to saving your batteries for times of need, the disengagement of the battery compartment means that your batteries won’t leak acid or erode inside the light. Not only does this protect your Coleman® light, but also provides an extra level of safety for the user — the light is there when you need it.
Easy to use, designed to get the most out of your electric lights, and smart in engaging the batteries’ power – BatteryGuard™ makes it all possible!
2000033874
Weight .500 lbs
Dimensions 21 × 21 × 21 in
Coleman
Be the first to review “Coleman BatteryGuard™ 600L LED Lantern”
£14.99 Inc VAT
