Simplifies the connection between an outside water container into the caravan Top performance pump Suitable for microswitch or pressurised systems Choice of flow rate to suit either a simple one or two outlet system with two or more outlets including a shower. Incorporates an anti air-locking pump enhancing the performance of the WHALE water system The easily replaceable pump that can be removed and replaced if necessary Easy-fit plug stays secure Watermaster® with 12 V d.c. High Flow pump and plug for WHALE® Socket
EP1612
| Weight | 2.5 lbs |
| Dimensions | 39 × 39 × 29 in |
| Availability |
Whale
![7845378-80008-2-3-560[1]](https://pos.vwcaliforniaclub.com/wp-content/uploads/2020/10/7845378-80008-2-3-5601.jpg)
