Keep the fresh water in your Cali bacteria free and tasting great again.
Puriclean is non-toxic and non-caustic and has no taste or smell and does not foam or harm any components in your water system.
To use, just fill your water tank with a Puriclean solution and run through your pipes. Leave to soak for up to 12 hours and then drain and rinse the system. Your water system will then be clean and ready to be filled with fresh water again.
- Cleans and purifies all stored water systems in your campervan
- Eradicates bacteria, viruses, biofilm, algae and fungi
- Powerful action without harming the components in the water system
- Use at beginning of the season and then periodic use will ensure a clean healthy system for water storage
Puriclean can also be used to remove stains and clean many domestic items such as glassware, plastic tableware, tea and coffee pots, china, cutlery, stainless steel and vacumm flasks.
Part: CL100
Frequently bought together
| Weight | .250 lbs |
| Dimensions | 18 × 14 × 13 in |
| Availability |
