Bullfinch Fresh Water Inlet
Pressure limiter (set to 1.5 bar) prevents damage to internal piping and equipment installed (it does not reduce the pressure – it stops flow at pressures over 1.5 bar)
Fits universal hose connections
Connection into caravan/motor home system takes 12mm push fit pipe for easy connection
Dual usage: water fill up from mains supply and from an external tank with an external submersible pump. It is not suitable for systems which draw water in using an internal pump inside the caravan, motor home or building.
Simple installation – you will need a 60mm dia cutter
Care must be taken not to create a pressured system during installation and filling, damage to the water storage tank may result. If unsure please consult a local installer.
The tank needs to be vented or the taps turned on during filling. The water point does allow air to be sucked into the system when water is being used
Colour: White
Model: MM6097
| Weight | 2.5 lbs |
| Dimensions | 39 × 39 × 29 in |
| Availability |
