.The Floë system makes it easy to drain your motorhome or caravan’s water system, flushing pressurised air down your caravan or motorhome’s pipes, through the tank, any pumps or mixer taps.
Quickly clearing and drying the system, the Floë system helps to prevent stagnant water, frozen pipes, bacteria growth and keeping your system clean and fresh without hours of work. Simply hook up to either a foot pump or a 12v/240v air compressor and you’ll be able to clear out the water in no time!
The Floë Ultraflow Draining Kit works with Truma Ultraflow plugs and sockets, perfect for draining your touring caravan. The Floë drainer fits to the Truma Ultraflow pistol plug, fitting snugly into the side of your caravan.
With a UK water-tap connector, ½” reducer and the Floë easy to use drainer, as well as full instructions on DVD.
Please note: Please always read the instructions thoroughly before use and do not pressurise the system above 15psi.
Features:
Drains the water system
Flushes pressurised air through pipes, taps, tank and pumps
Truma Ultraflow pistol plug connector, UK water-tap connector, ½” reducer, Floë drainer and full instructions on DVD included
Truma
