Truma Ultraflow Water Pump Assembly – 800mm
The Truma Ultraflow Water Pump assembly is an ergonomic and simple solution that enables you to pump water into your vehicle from an external source such as your water carrier. The Ultraflow assembly connects conveniently with your Aquaroll or Waterhog and is compatible with both the Ultraflow Filter Housing and the Ultraflow Compact Housing. The water pump with ergonomically shaped pistol grip can be plugged into the filter or compact housing type connection, for use in your caravan and motorhome freshwater tank. Please note, do not run the pump dry as this may cause damage. This ultraflow submersible pump is available in an 800mm length, ideal to connect to your water carrier. The ideal water pump to use in your caravan or motorhome.
Connects conveniently with your Aquaroll or Waterhog
Compatible with the Ultraflow Filter Housing
Compatible with the Ultraflow Compact Housing
Ergonomically shaped pistol grip
Ideal for use in a caravan and motorhome fresh water tanks
Specifications
Hose length: 800mm
Model reference: 46040-01
Barcode: 4052816014944
Truma
![IMG_20150919_123939247[1]](https://pos.vwcaliforniaclub.com/wp-content/uploads/2015/09/IMG_20150919_1239392471-350x350.jpg)
