Brandrup ISO-TOP MK V for the pop-up roof of the VW T6.1/T6/T5 California Coast/Beach for Manual operated roof
£499.99 Inc VAT
Out of stock
Side Zipped windows only – please note this has no zipped front window in the isotop – images for illustration pupose only.
ISO-TOP the all-round solution for all seasons: It Isolates and protects effectively from cooling by wind infiltration – Ideal for temperatures between approx. -5° to +45° C.
ISO-TOP is designed for the use all year round: An isolating air cushion is created between the gaiter and the ISO-TOP, which is also effective in high temperatures – also in midsummer it is noticeably cooler under the roof. When the windows are opened, a refreshing air current is achieved and the double wall (gaiter + ISOTOP) dams the heat.
If it is cold, the warm air from the parking heater is hardly “blown away” through the gaiter.
The new high-tech material is highly breathable and absolutely windproof. The windbreak, the reduction of dampness, the indoor climate and safety are excellent. The ISO-TOP membrane also protects the bed mattress from humidity, when closing the top with a wet gaiter: additionally to thermal insulation (cold/heat), ISO-TOP offers an efficient protection against humidity and absorbs exterior noise. The membrane on the reverse side is black to ensure a better sleeping environment.
There are big windows with zipper on three of the sides (if you have a 2 windows beach or coast the front becomes unusable). If there is a front opening in the gaiter, ISO-TOP can also be opened completely.
ISO-TOP Mark V is the classy, cosy “year-round inner tent”, which does not need any additional storage space and is always ready for use without any further effort as soon as the parking position is reached.
ISO-TOP MK V remains mounted inside the pop-up-top:
the top can be closed with the ISO-TOP installed inside!
Lower fixation with hook-and-loop fastener all around: Cold air cannot penetrate into the berth.
The attachment above has a precise attachment and the best possible seal.
At the front ISO-TOP is attached with hook-and-loop fastener to five special holding-pads in the electrohydraulic operated pop-up roof, which have to be permanently fixed to the front interstice of the roof lining.
In the manually operated pop-up roof ISO-TOP is attached with hook-and-loop fastener to three special holding-pads.
Attention! For California pop-up-top (with or without ISO-TOP): while closing the top, only a window or door which is opposite to the wind direction (lee) has to be kept open!
All windward windows and doors have to be closed.
100 701 071 – ISO-TOP MK V pop-up roof insulation for the VW T6.1 / T6 / T5 California Coast / Beach with manual operated pop-up roof
Brandrup
Be the first to review “Brandrup ISO-TOP MK V for the pop-up roof of the VW T6.1/T6/T5 California Coast/Beach for Manual operated roof”
You may also like…
£499.99 Inc VAT
Subtotal: £161.84
View basketCheckout
