Comfortz VW California ‘Cali-Wrap’ – Thermal Roof Wrap
Price range: £279.99 through £374.99 Inc VAT
**Please be aware due to Holidays there’s a 2 weeks wait time on this product** Back to normal 06/06/2022
Here we have the new VW California Cali-Wrap from Comfortz Leisure. Fits the T5 & T6 SE, Ocean and Beach (The exception to this is 2005-2006 Californias, please call to discuss)
This insulated easy to fit wrap comes in various colours to make your California stand out from the crowd. It provides full black out for the roof of the California (With the T6 light is often an issue) and is also completely reversible with a reflective silver on the inside for the sunnier climates. As well as keeping the upstairs nice and warm we have also noticed a slight reduction in background noise from the campsite.
Fitting is a simple as wrapping the screen around the roof canvas of the California and fed behind the mechanisms and struts of the roof. The Cali-Wrap must be removed when lowering the roof and we have found that a small plastic stool (which can be kept in the tailgate with the chairs) helps with the fitting.
Great option if using solar panels on the roof or roof bars and boxes.
Available to choose with PVC Windows, Side Vents or with nothing at all , (SE / Ocean 3 windows – Beach / Coast 3 or 2 side windows)
If vents are chosen for an Ocean – this will come with 2 side vents and 1 PVC window in the front.
Key Features
Fully insulated
Waterproof
Offer a black out for the roof
Various colours
Easy to fit and remove
Reversible for hotter climate
Reduces noise
Pack Size – 20cm x 20cm x 107cm
| Weight | 7 lbs |
| Dimensions | 102 × 32 × 32 in |
| Windows / Vents? | Nothing, PVC windows, Side vents |
| Colour? | Black, Royal Blue, Forest Green, Light Grey, Mid Grey, Purple, Maroon, Yellow, Red, Navy Blue |
| Model | Beach 2 Side Windows, Coast 2 Side Windows, Coast 3 Windows, Ocean 3 Windows |
| Availability |
Comfortz Leisure
3 reviews for Comfortz VW California ‘Cali-Wrap’ – Thermal Roof Wrap
You may also like…
Kampa Hottie Portable Gas Heater
Original price was: £53.95.£48.95Current price is: £48.95. Inc VAT
Paul Briody (verified owner) –
Easy to install and provides good insulation against wind and rain. Disappointing that there is no cover to put across the window when not being used which means you dont get a blackout when trying to sleep. Other makes have an insert which slides in between the campervan layer and the roof rap and I wrongly assumed this product would have the same. Hence 3 stars
Steven Hagger (verified owner) –
Really Nice Cover. I like the clear plastic window at the front so you can see out in the rain. The side vents to let a bit of air in on the sheltered side is good too. The vertical poles at each corner make.it much easier to fit than a cover I had without. Overall very pleased.
Heath Arnfield (verified owner) –
Arrived in very good time and for a first time user simplicity itself to set up. I would hazard a guess at 10 minutes at most.
Thermal efficiency is great and it also dampened down some site noise a little. It just means we can extend the camping season for longer every year now!
