Comfortz VW California Winter Pack (Cali Wrap & Windscreen Cover)
Price range: £394.99 through £490.00 Inc VAT
Order our California Winter Pack and save – includes a Cali-Wrap + Thermal Windscreen Cover
Please allow 5 days for dispatch
Cali-Wrap
This insulated easy to fit wrap comes in various colours to make your California stand out from the crowd. It provides full black out for the roof of the California (With the T6 light is often an issue) and is also completely reversible with a reflective silver on the inside for the sunnier climates. As well as keeping the upstairs nice and warm we have also noticed a slight reduction in background noise from the campsite.
Fitting is a simple as wrapping the screen around the roof canvas of the California and fed behind the mechanisms and struts of the roof. The Cali-Wrap must be removed when lowering the roof and we have found that a small plastic stool (which can be kept in the tailgate with the chairs) helps with the fitting.
Great option if using solar panels on the roof or roof bars and boxes.
Available to choose with PVC Windows, Side Vents or with nothing at all , (SE / Ocean 3 windows – Beach / Coast 3 or 2 side windows)
If vents are chosen for an Ocean – this will come with 2 side vents and 1 PVC window in the front.
The key features of the Cali-Topper are;
  • Fully insulated
  • Waterproof
  • Offer a black out for the roof
  • Various colours
  • Easy to fit and remove
  • Reversible for hotter climate
  • Reduces noise
  • Pack Size – 20cm x 20cm x 107cm
Thermal Windsceen Cover
Specifically designed to keep the California warmer in the winter and cooler in the summer. This is achieved by sandwiching a layer of insulation between two layers of UV reflective polyester – reflecting heat away from the outside in the summer and heat back internally in the winter. This cover is super easy to fit – by the means of two door pockets which hook over the top of the doors and tabs which attach around the wing mirrors. The front screen also detaches from the side panels so you can drop it down in the day if extra light is required.
The cover also fits into a storage bag roughly half the size of similar products on the market!
The key features of the cover are
Great for both summer and winter use,
Rip resistant,
Easy to fit and remove,
Compact and light weight
Made in Great Britain with full 12 months warranty
Windows
With Windows, Minus Windows, With Vents
Windscreen Cover Type
Reflective Silver, Mid Grey, Light Grey, Black, Royal Blue, Navy Blue, Forest Green, Purple, Orange, Yellow, Marron, Red
Wrap Colour
T5, T6, T6.1
Powered With Oliver Pos
Comfortz Leisure
Be the first to review “Comfortz VW California Winter Pack (Cali Wrap & Windscreen Cover)”
You may also like…
