Volkswagen T5 T6 & T6.1 Spare Wheel Anti theft device.
Spare wheel theft is a rising problem ( just read our forum) among Vehicles with their spare wheels stored beneath the vehicle.
- The Sparesafe locking system will deter even the most determined thief .
- Made from thick formed steel and powder coated for rust protection in bright red as a visible deterrent.
- Also for use with other VW T5 T6 & T6.1 Transporter variants including Caravelle, Kombi etc…
- This pack includes a Sparesafe + security spare wheel bolt and brand new key.
Please note: Not compatible with standard California wheel brace, a separate compact wheel brace is supplied in this kit
| Weight | 1 lbs |
| Dimensions | 19 × 13 × 14 in |
Reviews (17)
17 reviews for SpareSafe – T5 T6 & T6.1 Spare Wheel lock (inc Security Bolt)
Maurice (verified owner) –
Arrived via DPD..which is very good because you know within 1 hour when it is due to be delivered. Sparesafe is very well made and extremely easy to put on. My spare is the original factory tyre and I do not want it removed by anyone but myself. This should provide the necessary security. Definitely recommend.
Christoph (verified owner) –
Very nice piece of kit. Takes 5 minutes to install. Good quality and comes with everything you need. Even a small case to keep the original bolt and some bits and pieces is included.
Stewart (verified owner) –
Agreed the DPD delivery is the best. Seems a good piece of kit and easy to fit. The small cover to keep the security bolt head clean looked like it would be a nightmare to remove in a real life situation so I left it off and keep a piece of foam shoved into the underside of the Sparesafe. A large plastic cover threaded into the entry hole would be much better I think.
Yacine (verified owner) –
je les mis pour une raison, que que des personnes qui se sont fait volé les roue des secours en une nuit dans le même place de parking
pour ça que je les commander sur votre site
James (verified owner) –
Fast efficient service and highly recommend our Everything California VW shop. Easy to fit and looks the part. Sprayed the bolt with waxoyl rather than use plastic cap so will require minimal if any maintenance.
dave bremner (verified owner) –
Easy to fit, has long bolt so fits the alloy wheel. Looks durable.
iainbassnett (verified owner) –
Speedy delivery. Easy to fit and we now have peace of mind that the spare tyre is not going to “disappear”.
eugenecoleman (verified owner) –
Arrived quickly and easy enough to fit.
Simple but effective ( hopefully !)
rebeccajones27 (verified owner) –
After hearing the troubles of people having their spare wheels stolen we made sure to fit this the day our Cali arrived! Works well – we also have a red/white Cali so red colour suits us well (not sure how good it would look on any other coloured Cali mind!). Overall does the job, albeit a little overpriced.
brbspan (verified owner) –
Great service as usual. Easy to fit, strong piece of kit, have peace of mind now.
jimwoolleys (verified owner) –
Nearly came when promised; I got a text message from DPD saying that they were unable to deliver because of lack of telephone and contact details. However, 10 minutes later it was delivered. I told the delivery driver that I had been texted it couldn’t be delivered and he muttered something about a systems failure.
However, the kit is strong and relatively easy to fix on the wheel housing. I had not inspected or removed the spare wheel before and didn’t realise just how easy it would be to steal without this added protection. It would take somebody with a standard wheelnut spanner under a minute to whip the nuts off and escape with a brand new wheel / tyre.
rayplant (verified owner) –
Arrived promptly, appears sturdy enough to be a good deterrent, very easy to fit complete with replacement security bolt. All now fitted with a good coating of graphite grease to bolt.
degsaith (verified owner) –
Item arrived promptly by Royal Mail. Good service as usual. Prompted to buy the item after reading how many owners had their spare wheel stolen. Fitted easily and also added some grease as suggested by previous reviewer (thanks). Pleased with the result.
dereksene (verified owner) –
Fantastic product, gives you a complete peace of mind that when you need your spare it will be there.
shaunreason (verified owner) –
When I looked at how easy the spare wheel was to remove, so buying some sort of locking mechanism became a priority. Fitted very easily and feel much happier – it seems very secure now. The Cali wheel brace does not seem to fit far enough in to access the locking mechanism nut but I had in my tool box a longer slightly slimmer socket that works fine.
acooper (verified owner) –
Well designed and manufactured system and fast delivery.
It would be useful to have a press fit cap to fit over end of the bolt tube. A slight concern if mud collected in the recess it could prove difficult to locate the locking nut in the key.
Andy Cooper
Peter Guiton (verified owner) –
A must have item peace of mind for the spare
