Kampa Damp Buster Moisture Drain
(1 customer review)
£15.99 Inc VAT
In stock
SKU: 5060145394063 Category: Tag:
Caravan, Motorhome and Boat moisture draining trap, designed specifically for recreational vehicles to keep moisture and condensation under control and protect against musty odours and mildew. For use with moisture absorber Crystal refills (not supplied). Which absorb the water vapour from the air. Absorbs up to 3 times its own weight in water, each refill pack can absorb up to 3.5 litres of water and lasts up to 4 months. As the moisture is drawn from the air, it collects on the surface of the crystals and then drips into the bottom of the container. Moisture removed from the air is converted to brine and can be safely disposed of.
  • Made especially for caravans, motor homes and boats but also ideal for summer houses, beach huts, sheds, conservatories & homes
  • Use all year round
AC0216
Weight 1.58 lbs
Dimensions 26 × 22 × 30 in
Powered With Oliver Pos
Kampa Dometic
Reviews (1)
1 review for Kampa Damp Buster Moisture Drain
  1. Janine (verified owner)
    I can’t believe how much moisture this collected over the winter – had to empty the tall container twice. I definitely think this was a better solution to a low temperature heater I used last year as there was no evidence of damp at all this spring.
Add a review
£15.99 Inc VAT
