1kg refill:
Absorbs damp. Helps to stop condensation, mildew and mould.
Keeps moisture and condensation under control
Helps combat the effects of damp, mildew and mould
Suitable as a refill for most moisture traps including the Kampa Damp Buster and Moisture Buster (AC0216 & AC0223)
Each 1kg can absorb up to 3.5l of water and lasts up to four months depending upon the amount of moisture in the air
Availble in 1kg refill pack
9120000874
| Weight | 1.03 lbs |
| Dimensions | 23 × 25 × 6 in |
Kampa Dometic
