Alde Caravan Wet Central Heating G12 EVO Antifreeze
£14.99 Inc VAT
In stock
Alde Premium G13 Antifreeze is pre-mixed with deionised water for the correct concentration. Ready to use for topping up uses Alde caravan and motorhome heating systems throughout this winter.
Recommend replacing the antifreeze in the system with the G13 formula. The silicated OAT corrosion inhibitor is compatible with the silicate-containing antifreeze used as a standard by most UK vendors and provides 5-year protection.
If you are changing over all the fluid in your van, Alde recommends that you will need an average of 12-15L to do so.
  • Provides 5-year protection
  • Can be used to top-up existing fluids
  • Suitable for all Alde heating systems
  • For Wet Water Systems. Ready Mixed Premium Quality Glycol for Heating Systems
4070-120
Alde
Be the first to review “Alde Caravan Wet Central Heating G12 EVO Antifreeze”
£14.99 Inc VAT
