Flexible LED Lighting Strips – Attached using the Vango Sky Track® System or hook and loop attachment provided
Remote Control – Allows you to adjust the brightness easily
Hook and Loop Ties – Included for additional attachment
IP67 Rated Lights – Protected from dust and capable of withstanding water emmersion between 15 cm and 1 metre for 30 minutes
Works with Voltaic Roll Away, Powerbank or any standard USB connection
LED Lights- 240 LED’s producing 2800 lumens create a warm and bright lighting effect
The Vango Sunbeam Flexi Light is the ideal light system for tents and awnings. Utilising flexible LED lights that never need to be replaced, the Sunbeam provides warm lighting that can be easily adjusted with a remote control to create an ambience that suits you.
Compatible with any power bank, it can also be powered via the Vango Voltaic Roll Away, or conveniently by USB. Attached using our innovative SkyTrack® II System, the versatile Sunbeam Flexi Light includes spare hoop and loop attachments for use in tents without SkyTrack®.
ACRLIGHTS3AZA2M
Frequently bought together
| Weight | 1.25 lbs |
| Dimensions | 20 × 7 × 22 in |
Vango
