The Vango Sunbeam Flexi 6m Light New for 2019, is the ideal light system for tents and awnings. Utilising flexible LED lights that never need replaced, the Sunbeam provides warm lighting that can be easily adjusted with a remote control to create an ambience that suits you. Attached using our innovative SkyTrack® II System, the versatile Sunbeam Flexi Light includes spare hoop and loop attachments for use in tents without SkyTrack®.
Specifications
- Flexible LED Lighting Strips – Attached using the Vango Sky Track® System or hook and loop attachment provided
- LED Lights- 360 LED’s producing 3400 lumens create a warm and bright lighting effect
- Remote Control – Allows you to adjust the brightness easily
- UK Plug & EU Adaptor – Includes a UK Plug and European adaptor
- Hook and Loop Ties – Included for additional attachment
- IP67 Rated Lights – Protected from dust and capable of withstanding water immersion between 15 cm and 1 metre for 30 minutes
ACPLIGHTS3MZW27
| Weight | 2 lbs |
| Dimensions | 24 × 7 × 27 in |
| Availability |
Vango
