The BRAND NEW Electric Eco Heater is a travel fan heater, which has been designed to swiftly warm up smaller spaces, such as your caravan awning, drive away awning or family tent, whilst easily packing away into your travel bag, due to the compact dimensions, making it an ideal cold weather companion for your next camping excursion; this portable touring essential doubles up as on oscillating cylindrical fan to help optimise internal air circulation throughout summer, using sweeping 70° warm/cool air output. We have implemented a modernized digital control panel, giving you the option of choosing from a number of variable heat settings, each of which are safeguarded with an overheat protection system and a cut-out safety trip switch, eliminating the risk of an average electric camping heater. An integral ‘timer’ function has been introduced, allowing you to fall asleep carefree, without compromising personal safety. This camping essential can be powered through a mains connection at the campsite.
Comes with fall over protection so if the heater is knocked over the heater will cut out.
- Modern Digital Control Panel
- Compact Cylindrical Design
- Automatic Overheat Protection
- Choice of Warm/Cold Air Output
- Cut Out Safety Trip Switch
- Integrated Timer Function
- Produced from Virgin PP Flame Retardant Materials
- 70 Degree Oscillation Fan
- Powered Through Mains Connection
Specifications
- VOLTAGE: 220v-240v
- CURRENT: 600w-1200w
- WEIGHT: 1.35kg
- CERTIFICATION: SAA/CB/CE/ROHS/EMC/PSE/KC
- FREQUENCY: 50hz
- TIMER FUNCTION: 0-9 Hours
- LENGTH: 14cm
- WIDTH: 14cm
- HEIGHT: 22cm
- PACK SIZE: 176cm (L) x 176cm (W) x 298cm (H)
ORBK0086
Outdoor Revolution
