Brandrup ISOLITE® for Inside for passenger compartment windows
In summer, the solar heat is reflected outwards. The interior reflecting lamination preserves the cold air inside the vehicle longer. In winter, ISOLITE reflects the cold outwards and the warmth back into the interior: “Isolated flask effect”!
The Brandrup ISOLITE is simply fitted into the windscreen frame and attached to the upper black strip of the glass and around the interior mirror with hook-and-loop fastener
ISOLITE is quickly attached and can be stored on the bed of the pop-up top.
Double glazing effect:
ISOLITE Inside is the absolute best insulation for driver’s and passenger’s windows.
ISOLITE is not only hung to the window pane but is fixed to the window frame with hook-and-loop fastener. By this, a perfect sealing on three sides is achieved.
The enclosed air (between window pane and ISOLITE) cannot circulate and escape upwards (summer) or downwards (winter).
The entire surface is always densely closed.
Made in Germany
Please note: This is for use with vehicles WITHOUT the rain sensor fitted.
100 701 561
Brandrup ISOLITE® for Inside cabin windows, All VW T6 WITHOUT Rain Sensors in the inner-rear mirror
£90.99 Inc VAT
