Kampa Premium Cover for VW T4/T5/T6/T6.1
(2 customer reviews)
£109.99 Inc VAT
Only 1 left in stock
The Kampa T4, T5 & T6 premium cover is an exact fit and uses Kampa’s proven triple layer SFS material so you can ensure that your VW Campervan is protected against the elements such as sun, rain, snow, dust, bird lime, tree sap, airborne pollutants and heat.
Triple Layer Protection
Outer Layer – Soft yet durable. This layer is designed to reflect the sun’s harmful UV rays and to prolong the life of not just the vehicle but the cover itself through the extra protection the outer layer provides.
Middle Layer – Let it breath. The middle layer is an aeror micropore breathable film. This allows for water vapour to escape yet prevents rainfall from penetrating. Our covers are not only water resistant but also breathable.
Inner Layer – Soft and non-abrasive. The inside layer is what rests against your vehicle which is why we use a soft and proven non-abrasive material to prevent scratches or rubbing of paintwork.
Why should I use a Kampa cover?
When your campervan is not in use it is still liable to damage from the elements. A campervan cover ensures that your campervan remains dry and clean when not in use, be it through rain or snow you can rest assured that your motorhome is protected, also excellent at protecting against bird droppings that can be an unnecessary hassle as they can cause serious damage to the paint if not cleaned off immediately but can be hard to spot when the vehicle is not being used.
  • Keeps your campervan clean and mildew free
  • Triple layer SFS material beads water on contact affording maximum resistance to rainfall and snow
  • Breathable – water and condensation under the cover can easily escape
  • Reduces internal heat build-up in the caravan and protects internal furnishings from the fading effects of the sun
  • UV stabilised
  • Tough and interlocking 4 ply seams with rot proof thread
  • Soft and lightweight – will not scratch
  • Elasticated hem provides perfect fitting
  • 4 zippers make the cover easier to put on and take off and offers access to the door of your van
  • Sewn-in, quick release buckles for easy installation and removal
9120001958
Weight 5.34 lbs
Dimensions 48 × 38 × 37 in
Powered With Oliver Pos
Kampa Dometic
Reviews (2)
2 reviews for Kampa Premium Cover for VW T4/T5/T6/T6.1
  1. Christopher Gault (verified owner)
    Seems well made, and I like the zip access to the van’s side doors. Took me a while to work out which was the front end of the cover vs back end as I had it on the wrong way to begin with trying to do it myself, but got there in the end. Time will tell whether it withstands the British winter!
  2. Sarah Johnston (verified owner)
    Good value for money. Easily fits over bike rack. Light.
    Let’s see how it copes with a British winter….
Add a review
£109.99 Inc VAT
