Milenco Triple 3 Caravan Level Set – 1 x Ramp Only
£26.99 Inc VAT
rose a
Only 1 left in stock
The Triple 3 Level with the Super Level Indicator which you can use for fast and easy levelling. Simply place indicator on the caravan floor to instantly see which step on your Triple level is required, for easy and simple levelling.
This is the new and improved version of the class leading Triple Level. It is one of the tallest lifting (120mm) 3 Step levels on the market.
The Level incorporates a lattice, high-grip upper tread surface. They pocket the wheel at every height eliminating the need for chocks. They have a solid base to stop sinking on soft ground or sand. High grip leading edge preventing slippage when approaching and avoiding the need for gripper plates.
This is a high quality and innovative product and has won multiple awards and has multiple patents worldwide.
- Complete with 1 x Triple Level 3 and 1 x Super Level Indicator
- Approximate Dimensions : 18cm High x 24.5cm Width x 61cm Length
- Height of each step: 4cm/8cm/12cm
- Weight: 2.5kg per level
- Capacity 1500kg per wheel = 6000kg Motorhome or 3000kg Caravan.
3278
| Weight | 4.5 lbs |
| Dimensions | 62 × 32 × 21 in |
| Availability |
Milenco
