This is the new and improved 2020 version of the class-leading Triple Level. It is one of the tallest lifting (120mm) 3 Step levels on the market.
The Milenco Triple Level is the tallest (160MM) 3 Step level ever made. The Level incorporates a lattice, high-grip upper tread surface. They pocket the wheel at every height eliminating the need for chocks. They have a solid base to stop sinking on soft ground or sand. High grip leading edge preventing slippage when approaching and avoiding the need for gripper plates.
- Pair of Milenco Triple 3 Levellers
- 18cm High
- 24.5cm Width
- Height of each step: 4cm/8cm/12cm
- Weight: 2.5kg per level
- Heavy-duty and extremely durable
- Comes complete with carry bag
2936
| Weight | 4.5 lbs |
| Dimensions | 62 × 32 × 21 in |
Milenco
