Use gas safer with GasStop!
SAFE: 100% auto shut-off in the event of a major gas leak
SIMPLE:Easy to install and use, no professional help needed
PRACTICAL: A useful indicator shows when gas is running low
GasStop is an emergency gas shut-off device for bottled and portable gas systems used for camping, caravans, and motorhomes.
It instantly shuts off the gas flow if a leak occurs, and also includes a useful pressure gauge that lets you know when your gas is running low, letting you plan your refill ahead of time.
GasStop can also be used to test for minor leaks prior to using your gas – you should always check to make sure your gas system is leak-free!
- Ideal for caravans, motorhomes, boats and more
- 5 year manufacturer’s warranty
- For propane LPG cylinders using low-pressure regulators (up to 50 mbar)
MKGS111
| Weight | 0.86 lbs |
| Dimensions | 43 × 32 × 4 in |
