Caravan bulkhead Regulator c/w 8mm Adaptor for Copper Pipe
£25.50 Inc VAT
Out of stock
Caravan Regulator c/w 8mm Adaptor for Copper Pipe
- Conforms to standard 12864 annex D,
- For Caravan & Motorhome use only,
- Suitable for all liquified petroleum gases, propane & butane
- Supply pressure: 0.3 16 Bar
- Regulating pressure: 30 mbar (35 mbar, min 30 mbar)
- Inlet fitting 20×1.5 m left hand thread
- Outlet Fitting; Compression fitting 8mm
R43008
| Weight | 0.86 lbs |
| Dimensions | 43 × 32 × 4 in |
Pennine Leisure Supplies
