Propane 1500mm Pigtail Hose Pipe
£12.99 Inc VAT
Out of stock
1.5m propane pigtail gas hose with M20 fitting to attach to a standard propane bottle and at the other end a M20 nut fitting – fixes directly onto the caravan or motorhome via fixed bulkhead regulator that will be fitted to all caravans and motorhomes from 2004 onwards
Caravan Connection: M20 / W20
High pressure LPG hose
R15HPRO
| Weight | 0.86 lbs |
| Dimensions | 43 × 32 × 4 in |
