Gallant TV/Monitor Headrest Mounting Bracket for VW T4 T5 T6 T6.1 California, Caravelle, Campervan
£42.99 Inc VAT
Out of stock
The TV/Monitor Headrest Mount enables you to securely attach your TV to any headrest quickly and easily without the need for a permanent fixing. The mount is perfect for Campervans and Motorhomes, and can be moved to another seat or even another vehicle if you wish. The mount has the VESA Standard connecting plate with 75mm and 100mm hole centres and will hold most TV’s from 14” up to 27”.
The arm will rotate up to 180° from side to side. The mounting plate will rotate up to 180° from top to bottom. The mounting plate will also rotate through 360° enabling the TV to be levelled.
Made to fit headrests with bars that are between 120mm and 160mm apart at the centres – Standard seats in the VW T4 T5 T6 & T6.1
- Headrest Fixing Bracket
- TV Connecting Plate and Fixing Screws
- Fitting Instructions
- No need for permanent fixing to your vehicle or cabinets
- No tools required to fit the mounting bracket to the headrest
- Adjustable to fit any headrest (with bar centres from 120mm to 160mm)
- High quality sturdy aluminium construction
- Holds TV securely in place
- Thumb screws to enable easy fitting and adjustment
- Interlocking gears on each connection to give a solid and secure fixing
- Compatible with the standard VESA 75mm and 100mm fixing hole centres
- Fully adjustable
- Fits screen size from 14” to 27”
- Holds up to 10kg in weight
011/013
| Weight | 0.85 lbs |
| Dimensions | 24 × 18 × 9 in |
You may also like…
£42.99 Inc VAT
