RidgeMonkey Connect Compact Sandwich Toaster Inc Case & Utensils – Standard
£16.95 Original price was: £16.95.£12.00Current price is: £12.00. Inc VAT
Out of stock
The best just got even better!! The all new Ridge Monkey Sandwich Toaster features a unique detachable hinge system that allows the pans to be used independently if required, one-touch removable handles and a fluoropolymer non-stick coating that is second to none, the new RidgeMonkey Connect Compact Sandwich Toasters raise the cookware bar once again!! Perfect for preparing a variety of snacks from a humble toastie right the way through to a full meal and everything in between.
- Lightweight die-cast aluminium pans
- Fluoropolymer non-stick coating
- Ridged exterior for even heat transfer
- Cool touch removable handles with magnetic lock
- Unique detachable hinge design
- Sleek GunMetal Grey finish
- Can be used on all traditional stoves (not suitable for induction hobs)
- Full utensil set and neoprene case included
Standard 180mm (295mm with handle) x 155mm x 40mm
Optional Extra – Gorillabox https://vwcaliforniaclub.com/shop/product/ridgemonkey-gorillabox-toaster-case-standard
RM124
Frequently bought together
| Weight | 1.5 lbs |
| Dimensions | 31 × 24 × 10 in |
| Type | With Standard Case, With Free Gorilla Case – Worth £19.99 |
2 reviews for RidgeMonkey Connect Compact Sandwich Toaster Inc Case & Utensils – Standard
You may also like…
Related products
Paul Barnes (verified owner) –
Small but works great for 2
alangjackson (verified owner) –
This is a cracking bit of kit. Its the size of a piece of sliced bread so you can make toasties really well. The fact that the pan can be turned upside down, to cook both sides, allows you to make the best two egg omelette ever. Egg and bacon bagel toasties are our current goto breakfasts.
