Whale Standard 12v Water Pump
£14.99 Inc VAT
Only 1 left in stock
Standard Submersible Electric Pump 10 ltr/min, 2.4 amps .0.6 Bar, 12 V d.c. Simple, compact and an economical solution Long life, very quiet with low power consumption An inexpensive way to update a manual to an electric system Maximum continuous operation should not exceed 15 minutes Do not run pump dry as it will cause pump damage Do not use to pump water that is over 60oc We recommend the pump stands vertically in the tank Before switching on, place the pump in water and shake for a few seconds to release trapped air. This will ensure successful priming and should be repeated after refilling the water tank
GP1002
Weight 2.5 lbs
Dimensions 39 × 39 × 29 in
Powered With Oliver Pos
Whale
Be the first to review “Whale Standard 12v Water Pump”
£14.99 Inc VAT
