The Easy fit drawer kit has been specially designed for the VW California. They fit in the righthand cupboard under the sink and you can still close the door. This handy drawer unit will be a great addition to your van allowing you to store your items neat and tidy. Made from the original VW drawers and soft close runners which will match the original drawer in your van perfectly.
- Very handy storage solution.
- Made with the Original VW drawers.
- 3 drawers
- Soft close runners
- No drilling required
The 2 rails come with 3 runner attached and ready to fit.
Kit contains :
- 2 rails with 3 runners attached to each one and heavy duty double sided tape attached.
- 3 Orinigal drawers
- 2 alcohol wipes
This can also be fitted by us for on site for £30 – please get in touch for further details
Reviews (8)
8 reviews for VW California T6 / T6.1 Easy Fit Drawer Kit
You may also like…
Brandrup Velour carpet for passenger compartment, VW T6/T5 California Ocean/SE “Palladium”
Price range: £169.99 through £179.99 Inc VAT
Alan Mead (verified owner) –
Well, I’ve fitted them, and they look really neat – 5 stars for looks. It took me somewhat longer than the guy in the video – mostly time spent plucking up courage to position the runners, knowing that once in place I’d not be able to move them. I thought I’d got it right but probably one millimetre further back would have been better as the drawer fronts just caught the sliding door at first, until I forced home the tangs to their maximum extent. It’s still close. Having now shifted the Ridgemonkeys and other assorted cooking items to the other cupboard, I’m now wondering where I’m going to place tall food items. I dream of driving with a clear rear compartment but am beginning to wonder if a large “really useful” plastic box might now be required for the food. If only I could convert the wardrobe to an easily accessible larder. Very pleased with the drawers though and the only reason I’ve given 4 stars is that they are a tad expensive (although I see the remaining one in stock is £41 cheaper).
kevfrombournemouth (verified owner) –
Another great product, but had similar problems with alignment, fitting in our 2020 T6.1 Ocean. I wondered whether the T6.1 cupboards curvature is slightly more defined, therefore you need to position a couple of millimetres behind the existing draws front frame alignment, this avoids them catching the door, when closed.
They look great and makes storage, so much easier. Would recommend, just take care when fitting.
David Brown (verified owner) –
Quality product, really easy to fit. Expensive but seem worth it.
Julie Livingstone (verified owner) –
Very pleased with these drawers, easy to fit and work nicely with the soft close. It’s a shame that the shelf taken out cannot simply be fitted to the left side without the need for drilling additional holes.
Bigrodders (verified owner) –
Easy to fit and excellent quality, the wife loves them
anthony.farrar (verified owner) –
Excellent product. I fitted them to my T5 although I was told you couldn’t. A member of the California Owner’s club illustrated a way of doing it. I fitted them and the sliding door hit them. It is possible to move them once they are stuck – a bit of leaverage is required. I ended up with two kettles left over (normal and electric) as they could not fit anywhere. Moved them next door. Overall a useful and much more convenient method of storage. Expensive but once you have spent the money, don’t think about it.
Vernon Hall (verified owner) –
Fairly easy to fit.
The only issue is the lack of a way to secure the rear of the drawer runner to the drawer unit.
If you open the draws fully they disengage from the runner.
I ended up using duct tape to secure, which was a faff and not ideal.
Paul Jackson (verified owner) –
I ordered these to improve the overall storage capacity and ease of storage of my T6 Ocean. I found them extremely easy to install but less easy to adjust to get the best setup.
Watch the video it is helpful but clearly this is being done by someone who is very familiar with the process, once the runners are in place they would be extremely difficult to remove.
My lessons would be;
Check the measurements as they are given in the instructions and then tighten the screws. If they are loose when you try and install the drawer it will move and you have to measure and adjust again.
Make sure the rear tangs are square, they are easy to adjust with long nosed pliers.
I would recommend installing 3mm back from the existing drawer, reason for this is that if you adjust the height the sliding catch on the cupboard will be compromised and makes it difficult to open.
Great product, well designed and adds value to the van.
