The Vango Sizzle Induction Hob has been specifically designed for outdoor use with its 800W power. A heating lock ensures your pans stay warm whilst cooking and its wipe down surface makes cleaning up simple! Compatible with stainless steel bottom pans only, making our Gourmet Cook Set the perfect companion. It’s automatic pans sensor will let you know if your cookware isn’t compatible.
- LED Controls – Easy to use
- Automatic pan sensor – must be stainless steel bottom pans, audible beep if incorrect
- Integrated cooling fan – Reduces the risk of overheating
- 2.5m cable with UK plug – Extra long cable provides flexibility for cooking
- Power: 800 Watts – Designed for outdoor use with a max temperature of 200oC
- Heating lock – Ensures pans are kept warm
- 12/21cm cooking area – Suitable for use with pans 12/21cm in diameter
- Wipe down surface – Easy to clean
- Storage bag for easy transportation
- Product Sizes – 19cm x 23cm x 6cm
ACQSIZZLEB05TJ8
Frequently bought together
Vango
Reviews (1)
1 review for Vango Sizzle Induction Hob
Maria Funnell (verified owner) –
Very happy with hob and perfect for the job!
