No pans needed with the Vango Scran Griddle Range! The non-stick cooking plate has the option of a flat or ribbed surface, providing a healthier cooking style and is simple to clean. The adjustable thermostat lets you set temperatures to your desired heat and the heat resistant handles make it easier to move around.
- Power: 1500 Watts – Allows for efficient cooking
- Flat or ribbed non-stick grill plate option – Healthy cooking options and easy to clean
- Adjustable 5 setting thermostat with light indicator – Control the temperature whilst cooking (80-240oC)
- 2.5m cable with UK plug – Extra long cable provides flexibility for cooking
- Heat resistant handes – for added protection
- Leg Height Adjuster – allows unwanted grease to easily drain away from food
Specifacation
- Weight:2.5kg
- Packsize: L81.5 x H13.5 x W30.0cm
ACQSCRAN B05SO8
Frequently bought together
| Weight | 2 lbs |
| Dimensions | 42 × 12 × 31 in |
Vango
Reviews (1)
1 review for Vango Scran XL Low Watt 1500 Watt Griddle Cooking Plate
Thomas Clinton (verified owner) –
What an absolute revelation this bit of kit is, makes basic meals so much easier than messing about with gas cannisters and regulators, we have been so pleased with it taking it away twice in the last month!
The only issue we have had was that it came with very slight damage to the non-stick coating, however it is very small so we ignored it and have had no issues at all!
