Vango Driveaway Awning Kit – 6mm to 6mm ( 4 Metre )
The Vango Drive Away Kits are suitable for all drive away awnings. The size of drive away kit you require depends on what you are attaching your awning to, if you have any questions please contact us before purchasing.
The kit contains:
- Plastic Figure 8 connector to the correct length
- Double sided kador strip (6mm on one side and 6mm on the other)
| Weight | 1.75 lbs |
| Dimensions | 102 × 13 × 10 in |
Vango
