Outdoor Revolution Single Driveaway Fixing Kit 6mm – 6mm x 2.6m
£22.95 Inc VAT
Only 1 left in stock
Outdoor Revolution produce a wide variety of Drive Away Kit options in order to aid the drive-away process on a drive-away awning and make your holiday that little bit easier. One side of the grey Kadar material slides into the awning channel on your campervan or motorhome, whilst the other fits into the ‘Figure of 8’ strips which slide simply onto your awning beading. This allows you to disconnect & re-connect the awning with the vehicle in situ.
ORDA0004
| Weight | 2.2 lbs |
| Dimensions | 80 × 10 × 20 in |
| Availability |
Outdoor Revolution
