The Kampa Dometic Twin Drive Away kit has dual beading kador of both 6mm and 4mm so you can connect your awning to most wind-out awnings and awing rails.
The Twin Drive-Away Kit also includes 4 x 75cm lengths of figure of 8 sections and a 4 metre length of double edge twin kador.
- Dual 6mm & 4mm beading for connecting to both wind-out awnings and awning rails.
- 100% secure attachment
- Compatible with C-Channel Rail, Reimo Multi Rail and VW Factory Rail
- Compatible with Fiamma, Thule and Dometic Wind-out Awnings
AC0335
9120000412
Frequently bought together
| Weight | 1 lbs |
| Dimensions | 105 × 6 × 6 in |
Kampa Dometic
