Outdoor Revolution Twin Driveaway Fixing Kit 2M – 6mm-4/6mm
£23.99 Inc VAT
Out of stock
Outdoor Revolution produce a wide variety of Drive Away Kit options in order to aid the drive-away process on a drive-away awning and make your holiday that little bit easier. One side of the grey Kadar material slides into the awning channel on your campervan or motorhome, whilst the other fits into the ‘Figure of 8’ strips which slide simply onto your awning beading. This allows you to disconnect & re-connect the awning with the vehicle in situ.
ORDA0005
Weight 2.2 lbs
Dimensions 80 × 10 × 20 in
Outdoor Revolution
Be the first to review “Outdoor Revolution Twin Driveaway Fixing Kit 2M – 6mm-4/6mm”
£23.99 Inc VAT
