Thule WanderWay VW T6 / T6.1 Bike Rack / Cycle Carrier – COLLECTION ONLY
£525.00 Inc VAT
Out of stock
Please note: This product is currently for collection only / or can be delivered for £1.20 (approx) per loaded mile (From S44 5HS) Please call contact us for more details.
Fitting at our showroom is available for £30 – Please see here for more details – – ->https://vwcaliforniaclub.com/shop/product/fitting-service
In comparison to the original VW T6/T6.1 Bike rack (which is also manufactured by Thule) this rack arguably has a better colour scheme. The locking thumb screws clamps are upgraded with a torque thumb screws as to not over tighten, it can take E-bikes (making sure you keep under the weight limits) and has the new upgraded ratchet pump action wheel straps. It also comes with all the tools to fit to the T6 and the protective tape and fits to the tailgate exactly the same as the original VW rack.
The Thule WanderWay 2 is a top of the line tailgate bike rack for the VW T6. It is designed to transport 2 bikes, with the WanderWay 3rd/4rd adapter the loading capacity can be increased to up to 4 bikes. Thanks to the raised position of the rack, the view of the rear lights is maintained for following traffic.
This Rack unfolded extends the van by circa 82cm when unfolded and 40cm when folded up.
- Quick and simple to mount thanks to the dedicated fit to the VW T6 and the new T6.1
- Possible to increase load capacity up to 4 bikes by adding a third bike and a fourth bike adaptor (WanderWay 3rd Bike Adapter and WanderWay 4rd Bike Adapter sold separately)
- The raised position of the rack keeps the rear lights and license plate visible
- Easy mounting of bikes through detachable bike arms with lockable Thule AcuTight torque limiter knobs that click when optimal torque is reached
- Simple loading of bikes thanks to easy-to-adjust rails that slide from left to right
- Simple to fasten wheels, thanks to the adjustable wheel holders with pump buckles
- Platform folds up vertically against the trunk when not in use and folds flat for easy transport and convenient storage
- Locks the bikes to the bike rack (lock included)
- Possible to open vehicle trunk without any mounted bikes
specifications
- Max number of bikes: 2 (With WanderWay 3rd Bike Adapter and WanderWay 4rd Bike Adapter the capacity can be increased to 4 bicycles – not included!)
- Load capacity: 60 kg
- Dimensions: 152 x 47 x 91 cm
- Folded dimensions: 152 x 47 x 91 cm
- Fits frame dimensions: 22-80 mm
- Detachable frame holders: Yes
- Carbon frame compatible: Yes (With adapter Thule Carbon Frame Protector – Not included!)
- Rear lights and number plate visible with bikes mounted: Yes
- One Key System compatible: Yes
- Lockable bike-to-rack: Yes
- Lockable rack-to-vehicle: Yes
- Weight: 12.4 kg (Manufacturer information)
911001
| Weight | 18 lbs |
| Dimensions | 158 × 98 × 50 in |
Thule
4 reviews for Thule WanderWay VW T6 / T6.1 Bike Rack / Cycle Carrier – COLLECTION ONLY
Adele Townend (verified owner) –
We are so happy with the service from California club -CampervanBits- brilliant product that I think will prove to be very popular. Sleek new sturdy. We wanted this rack as we only have 2 bikes. However I understand you can buy additions for up to 4 bikes. Don’t even notice it on the back of the van with cycles attached. Would highly recommend quality product.
GEOFFREY FAIRFOULL (verified owner) –
I am really pleased with the Wanderway, well designed and of good quality, easy to lift the bikes on and off and really don’t notice its there most of the time, no hesitation in recommending it as a good choice of bike carrier for a VW6.1.
Steve (verified owner) –
Great product provided by an expert team at CampervanBits. Fitted with precision and courtesy.
alangjackson (verified owner) –
Easy to fit. Easy to remove. Holds two bikes incredibly well on long journeys. Adult bikes protrude over the roof line so I remove the saddles to save a bit on fuel.
