Please be aware the original bike rack on the California is made under licence by Thule.
You can not buy the genuine exact length arms from VW but Thule sell arms the same length or that are very similar in length.
These arms have the new updated thumbscrew from Thule so the thumbscrew will look slightly different from the original on the bike rack.
VW T6 easy-clamp bike holders, grab and hold your bikes at any position.
When choosing the arm you require, they are numbered going outwards, ie Bike Holder 1 is the nearest to the back of the van
please note the measurements are taken from the pin in the center of the gripping claw – to the center of the hole in the clamp that secures around the bike rack frame.
Bikeholder 1 with Lock (122mm)
Bikeholder 2 with Lock (262mm)
Bikeholder 2.5 with Lock (300mm)
Bikeholder 3 with Lock (412mm)
Bikeholder 4 (double claw grip- bike to bike) with Lock (150mm)
These are the closest arms to the original VW rack – without buying a full rack – please bear this in mind when ordering.
Frequently bought together
| Weight | N/A |
| Dimensions | N/A |
| Arm Position | Bike Holder 1 with Lock, Bike Holder 2 with Lock, Bike Holder 2.5 with lock, Bike Holder 3 with Lock, Bike Holder 4 with Lock |
| Availability |
1 review for Genuine Thule Replacement Arms for VW T6/T6.1 Bike Rack – Silver
You may also like…
Price range: £35.99 through £51.95 Inc VAT
graham.smith61 (verified owner) –
Disappointed when original arm threaded but replacement is great quality, and not too expensive. Slightly different bolt head but makes it easier to tighten. Very happy with it.
