Manufactured by Therford, the economical Activ range has the same advantages as the Thetford Aqua products, use similar dose, but are effective for a slightly shorter period.
Use 70ml per 10 litre of flush tank capacity. Provides a more effective flush and keeps the flush water fresh.
- Leaves a protective film in the bowl that prevents deposits from forming
- The lubrication action makes the blade of the waste holding tank easier to open and close
| Weight | .650 lbs |
| Dimensions | 18 × 13 × 14 in |
| Availability |
Thetford
