The Outwell 10L portable toilet is designed to be both practical and easy to use. The toilet has a compact design and a built-in carry handle and a detachable holding tank.
- Sturdy polyethylene material
- Easy open/close side latches
- Large waste outlet makes emptying easy
- Slide valve for effective leakage protection
- Bellows flushing pump
- Built-in carry handle
- Detachable holding tank
- Compact design
- Size: 35.5 x 41 x 29.5 cm (WxDxH)
650765
| Weight | 5 lbs |
| Dimensions | 44 × 32 × 38 in |
Outwell
