Elsan Deep Clean is specially formulated to clean and maintain your toilet cassette and other plastic waste tanks.
After deep cleaning, the use of Elsan Blue or Elsan Organic toilet chemicals will help give you perfect performance from your chemical toilet.
- Regular use keeps the waste tank like new and helps to prolong its life.
- For use with all plastic waste tanks
- Add 250ml of Elsan Deep Clean for every 5 litres of water, leave to soak for a minimum of 8 hours but can be left longer if required
- 1 Litre
DEEP01
| Weight | 0.65 lbs |
| Dimensions | 8 × 8 × 18 in |
Elsan
