Duo Tank Cleaner Concentrated is one of the newest members of Thetford’s well-known Concentrated family! Powerful, concentrated, periodical cleaner for the waste-holding tank and grey water tank. For a long, clean, and fresh life of both tanks! Use Duo Tank Cleaner Concentrated periodically to remove deposits from the waste-holding and grey water tank that build up over time.
- Removes limescale, encrusting, and grease deposits
- Technical parts inside the tanks are cleaned as well
- Prolongs the lifespan of the tanks
- No scrubbing required!
- Cleaning without damaging the technical parts inside the tanks
- 0.8L = 4 cleanings of the waste-holding tank (4x200ml)
- 0.8L = 1 cleaning of the waste-holding tank (200ml) + 1 cleaning of the grey water tank (600ml)
- For best results use 2-3 times a year
| Weight | 0.65 lbs |
| Dimensions | 8 × 8 × 18 in |
| Availability |
Thetford
