Thetford C250 Toilet Reed Switch
£11.49 Inc VAT
Only 1 left in stock
The Thetford C250 Toilet Reed Switch is a single one switch circuit board waste tank level indicator. This clever device switches on a light when the waste level is high in your cassette toilet, which is when the tank needs emptying. The circuit board incorporates the reed switch that senses the waste tank level, this is the basic version- described as the “one switch” model, designed as a replacement for the C250 toilet models – with only a flush button and a single waste tank level indicator. The circuit board switch has one reed switch fitted (the red bar component), the circuit controls the waste tank level indicator light only, ideal as a replacement for your C250 toilet in your caravan or campervan.
  • Toilet Reed switch
  • Replacement circuit board for your waste indicator light
  • Circuit board switch has one reed switch fitted
  • Suitable for the “one switch” model C250
  • Ideal replacement for use on your caravan or campervan
Specifications
  • Compatible with the Thetford C250 cassette toilet
  • Dimensions: 30mm x 40mm
50713
Thetford
Be the first to review “Thetford C250 Toilet Reed Switch”
£11.49 Inc VAT
