LED Lighting System – Add on Kit
Designed for use with our LED Lighting System Starter Pack (EL3001). The add on kit allows you to extend the Starter Pack by a further 1m lighting strip
Please Note: The starter kit is required to install the system and then you extend it with this add-on kit.
Kit includes:
1 x 1m LED light strip with magnets and cable tidies
1 x 3m cable
1 x 60cm cable
1 x 30cm cable
EL3002
| Weight | 0.50 lbs |
| Dimensions | 15 × 15 × 5 in |
