Kampa SabreLink Flex System – Add-on
An exciting new accessory for your tent, the SabreLink™ Flex lighting system ensures you’re never in the dark. The system allows you to link up to three lights together. Each system is controlled by a remote control that allows you to switch the lights on and off and also dim and brighten them.
The flexible lights simply velcro onto the AirPoles on our AIR tents. Also suitable for other tents using supplied fittings.
  • Avaliable as starter and add-on kits
  • Up to three lights can link together
  • Operated using a remote control
  • Brightness can be adjusted
  • Velcro fixings on all Kampa AIR tents and Travel Pod AIR awnings from 2017 for easy fitting
  • 45 super bright LED bulbs – never need replacing
  • Complete with mains adaptor in starter kit (UK and EURO plug versions available)
  • Suitable for other tents using the supplied fittings
9120000349
Weight 0.5 lbs
Dimensions 45 × 32 × 3 in
Kampa Dometic
Be the first to review “Kampa SabreLink Flex 45 LED Lighting System – Add-On”
£18.89 Inc VAT
