Designed to fill the gap in-between the end of the awning Air Poles and the side of your caravan or motorhome. Will aid when your awning is pitched on uneven ground.
- Air Volution Packing Pads: 12pcs in each pack
- Approx. size:12cm diameter
- Approx. depth:6mm
AC2020
| Weight | 1 lbs |
| Dimensions | 108 × 10 × 10 in |
