The Connect Toaster XXL Pan & Griddle Set has a detachable lid, offering great flexibility with how you can use it.
The Pan & Griddle set can be used as a single pan with a lid, or you can simply detach the lid to have two separate pans, one of which has a griddle plate. The set is ideal for large omelettes, pizzas, pastas, fried breakfasts, the list goes on.
No matter how you spend your time, this pan enables you to cook whatever you want, wherever you want. Indoors, outdoors, bankside, camping, caravanning or on BBQ’s. The Connect Toaster XXL Pan & Griddle Set features our market-leading Fluoropolymer cook-safe non-stick coating. The square shape and removable handles allow for easy storage. It also comes supplied with a cheese grater and Q-Lock Spatula to help create culinary perfection.
Market-leading Fluoropolymer non-stick coating
Ridged exterior for even heat transfer
Unique detachable hinge design
Neoprene pouch for handles included
Cool touch removable handles
Square shape offers easy storage by reducing wasted space
Detachable multi-purpose lid, doubles as a standalone griddle pan
Cheese grater and Q-Lock Spatula included
Handles and utensils can be stored within the pan when not in use
Can be used on all traditional stoves and direct heat sources, including open fires (not suitable for induction hobs)
Protected registered design
RM687
