RidgeMonkey Connect Compact Sandwich Toaster Inc Case & Utensils – XL Granite
£28.99 Inc VAT
Out of stock
RidgeMonkey Connect Sandwich Toaster Inc Case & Utensils – XL (New Granite Edition)
The RidgeMonkey Connect Sandwich Toaster XL Granite Edition features detachable cool-touch handles, a detachable hinge system that transforms one pan into two, and a full utensil set that fits inside the toaster, along with the handles, for easy storage. The square shape also means that there is less wasted storage space than with traditional circle shaped cookware.
Despite the name, the Connect Sandwich Toaster XL is not just for toasties, think pies, slices, naans, wraps, omelettes, cinnamon swirls – the possibilities are endless.
Our all-new granite-style coating makes our pans tougher, more durable, and offers improved non-stick properties taking compact cookware to a whole new level.
RM777
To go with the RidgeMonkey Connect Sandwich Toaster Inc Case & Utensils – XL (New Granite Edition)
https://vwcaliforniaclub.com/shop/product/ridgemonkey-connect-pan-griddle-xxl-granite-edition
Check out Ridgemonkeys full Granite range – https://ridgemonkey.co.uk/?s=granite
- Granite-style coating with improved non-stick properties
- 2x flat-bottomed frying pans
- 1x heat-resistant utensil set
- 1x set of removable magnetic, thermoset plastic cool-touch handles
- 1x protective pan pouch
- Detachable hinge system
- Lightweight aluminium construction
- Sleek Gunmetal Grey finish
- Ridged exterior for even heat transfer
- Can be used on all traditional stoves and direct heat sources (not suitable for use on induction hobs)
Frequently bought together
| Weight | 1.5 lbs |
| Dimensions | 31 × 24 × 10 in |
| Type | With Standard Case, With Free Gorilla Case – Worth £19.99 |
You may also like…
Related products
£28.99 Inc VAT
