The RidgeMonkey Bivvy Lite Plus: your guiding light in the dark. With variable brightness to suit your needs, the option to switch between three colours at the push of a button and up to 180 hours of illumination from a single charge via a standard 5V USB port.
The Bivvy Lite Plus sports a compact, lightweight design with magnetic fittings and backing plate, meaning it can attach to any bivvy, brolly, awning or tent as well as any nearby ferrous metal for your convenience.
The adjustable brightness control offers two user-friendly settings that can be adjusted using the integral multi-function button.
Specifications
- Lumens: 10-100 (dependent on setting)
- Battery life @ 15C: 6-180 hours (dependent on setting)
- Battery capacity: 2600mAh
- Recharge time: 4-4.5 hours
- Approximate Dimensions: 200mm x 36mm x 36mm
- Three colours – white, red and green
- Two brightness settings
- Integral multi-function button
- Built-in rechargeable lithium-ion battery
- Single LED power indicator
- Micro USB charging port
- Robust construction with sleek GunMetal Grey finish
- Protected registered design
- Adjustable Bankstick Adaptor included
RM121
Frequently bought together
